grouping large array into subset array
i don't want to beat a dead horse and you guys are very helpful but.  what if i needed to add one more boolean array.  for example the first boolean array would select the bits in index 0 and 2 and the second boolean array would select index 1 and 3.  the data from the second boolean array would go into the third column in the table.   i tried expanding the example vi given, but being new to labview, i couldn't get things to modify.  thank you
Message 11 of 13
(881 Views)
Just expand on the already posted code... (See attached, LabVIEW 8.0).
Message 12 of 13
(875 Views)
thank you
Message 13 of 13
(863 Views)
