group bar graph
Hello
Is there a simple method to display data on bar graph where various Y-values for given X are staying like neighbors
but not like one Y above another Y (I've seen on http://forums.ni.com/ni/board/message?board.id=170&message.id=315293&query.id=2383347#M315293) ?
I made a lot of manipulation on set up on a legend (Common plots, etc) without success.
The only idea I have is to artificially offset X for all Y-values like this (X11,Y1), (X12, Y2) etc... and then plot it.
I'm sure there is a easier way to get my expectation.
I enclose a simple view how I want to get.
Best regards
Konrad
(5,370 Views)
(5,359 Views)
hi cknio,
  Use the bar command and give your two dimensional array as input and specify the bar plot width....
  Just  try it.
Thanks and regards,
srikrishnaNF
Srikrishna
(5,344 Views)
srikrishnaNF
What you mean bar plot width or where to find it ?
I have LB 8.5.1, there is only Line Width for given plot and bar style ?
I can modyfie bars only in simple way as I showed below in the file, but this is not what i expect.
It is easy and first bar graph in Exel.
KNRD
(5,330 Views)
A different view
(5,320 Views)
Take a look on jpg on the top of this discussion. There is Exel view with bar graph a want to obtain.
 KNRD
(5,306 Views)
hi ckonio
  the particular bar command is a matlab command will be present in mathscript node..so please put a mathscript node and write the bar command ,adjjust the bar plot width and pass the two dimensional aray as input.
Thanks and regards,
srikrishnaNF
Message Edited by srikrishnaNF on 05-20-2010 08:50 AM
Srikrishna
(5,294 Views)
