greater than or equal function not working properly
Hi all,
Im curious if anyone has seen this before or knows why its not working.  I have a greater than or equal function and i am comparing two doubles.  Ive probed the numbers entering the function so i know that the 2 numbers entering the function are the same.
Problem is i dont get a true from the function until the comparasin value is greater than the number entering.
Using LV2011.
Any reason this happens?
Thank you,
Matt
-Matt
(5,310 Views)
Accepted by Ben
(5,302 Views)
Ok - and what was the exact solution?
(5,263 Views)
I actually dont know.  For me i just lowered the number it was compared to ha Smiley Very Happy in the link i posted it just says funny behavior can be expected.  I didnt really look any further into it.  What exactly would be the solution to this?
matt
-Matt
(5,260 Views)
The problem with floating points is that they are not exact.  If they are off by a bit or two, your numbers are not equal.  This is because a large majority of numbers cannot be accurately saved in 64 bits.
(5,236 Views)
That makes a lot of sense and I assumed something like that. The driver I was working with for an Agilent was using floating point inputs and outputs. That's why I left them in that representation. In this circumstance would it be a good idea to convert them to integers? I know some rounding will of course happen but I'm not too worried with the precision.
-Matt
(5,214 Views)
Hi Matt,
That depends on your numbers - you didn't tell us anything about them before…
When Agilent chose DBL datatype they did this for a reason (atleast I guess). So using integers instead might lead to other problems!
(5,196 Views)
