graph zoom problem
Hi there,
I am having a problem with the graph zoom function in LabVIEW 7.0
Zoom in/out/pan all work as expected, but the "unzoom fully" (first icon on second row) has no effect. Unfortunately this effect is a little difficult to reproduce, as if I create a blank VI and insert a graph everything (including "unzoom fully") works fine. But if I take this new graph, and copy and paste it into my original VI then the graph "unzooming" has no effect.
Does anyone have any thoughts on what I may be doing wrong?
Any help would be greatly appreciated.
(3,228 Views)
Hi nrp,
This could be something to do with the data that you are wiring to the graph. Please could you post a fragment of your code to the thread, so we can have a look.
Regards
Tristan
(3,227 Views)
Tristan,
Thanks for your answer.
I dont think its the I/P data, I have tried it just using a very simple one-dimensional array.
As I mentioned, the un-zooming works fine in one VI (even with the VI not running), but if I copy and paste the same graph into a new VI, the un-zooming breaks (all the other pan/zoom functions work fine)
(3,227 Views)
Nrp,
Sorry for the delay in getting back, are you still having problems with the un-zoom function. To clarify, if you copy and paste from the block diagram without changing any of the wiring, the un-zoom funciton does not funciton correctly?
Tristan
(3,227 Views)
