graph to spread sheet
how to save a front panel graph to a spread sheet file programatically?
(2,959 Views)
Hi Muralidharan,
what exactly do you want?
Writing the values to a text file or copying a picture of the graph into an Excel worksheet?
Saving to spreadsheet is easy using the WriteToSpreadsheetFile function... Read the help, look at the examples coming with LabVIEW!
(2,947 Views)
hello sir
I know to write the values to spread sheet file. But i want to save the front panel graph image in spread sheet.
Thanks and Regards,
Murali.
(2,942 Views)
Hey Muralidharan,
I would suggest that you use ActiveX to generate your graph in excel. But this is a two step process, first you will need to save the graph to file. This can be achieved using an invoke node of the graph and setting a file location. Once the file location has been stored you can use the activex functions to insert it into your excel document. I have sent a link that should help you to generate the activex function for your specific problem. If you get stuck at any point please feel free to ask and I will help as best I can.
How to create an invoke node of a graph:
http://forums.ni.com/t5/LabVIEW/How-can-I-easily-make-a-screen-shot-of-a-polar-graph/m-p/1198851#M51...
How to create the activex function:
http://forums.ni.com/t5/LabVIEW/How-can-I-add-excel-pictures-using-activex/m-p/1002526
Regards
Andrew George @ NI UK
(2,937 Views)
