graph the data from frames to the same indicator
GerdW,
thank you very much for the effort. Have any ideas how I can open your application ?- being modified in a later version seems to be a real impediment... it doesn't even show anything.
Dana
Message 11 of 15
(786 Views)
Hi Dana,
the vi from GerdW was saved for LV8.2. Here is a version for 8.0
Mike
Message Edited by MikeS81 on 03-04-2008 08:13 PM
Message 12 of 15
(774 Views)
Hi altenbach,
I wanted to approach your suggestion , too. But I may do a mistake because it runs pretty correct the initial state, but doesn't seem to pass to the next one. Have any ideas why?
Another remark would be that it's the first time when I use a desin pattern and I am prompted with the existance of a ctl file as a dependencie of the application. Is in normal/good?
Thanks a lot!
Dana
Message 13 of 15
(767 Views)
I solved the problem, thank you for all!
Dana
Message 14 of 15
(760 Views)
Hi Mike,
I guessed that was the problem... Thanks a lot for the solution!
Kind regards,
Dana
Message 15 of 15
(759 Views)
