graph/plot settings?
Hi.
I cant get the graphs to show the curve like it should. whwn plotting a squarewave it gets very strange. Probably it is not a difficult problem to solve but I cant find the soulution.
I attached a picture of the grafh som that you can understand what I mean.
Regards Fredrik
(3,628 Views)
Are you sure this is really a graphing problem? It looks more to me like a hardware configuration problem - like voltage ranges of a DAQ card or something similar.
Paulo
(3,625 Views)
the curve comes from a tds220 oscilloscope via GPIB to USB.
perhaps there is a setting within the instrument?
(3,621 Views)
Can you see the curve in the scope?
Is it similar to what you see in LabVIEW?
It seems to me it is somehow clamping at 0 and 5V, that's why I mention that it doesn't seem like a software problem.
(3,617 Views)
Yes the curve is fine on the scope. but not in labview... 😞
need help..
(3,591 Views)
Hello!
I don't think it is any idea to start looking at graph/plot settings in this case, what you should concentrate on is the GPIB programming, since this is most likely the cause of your problems. I cannot give you any more tips and hints since I don't have the instrument you specified and I don't know how your program looks like. I might be able to help you more if you attach the program you are using.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,557 Views)
ok thank you averbody.
I solved it by changing the number type from U8 to double in the instrument assistant.
(3,527 Views)
