graph interception
Good Day
which function in vi is suitable to use to know  the graph interception of coordinate 'X'  for cursor C refer to diagram attachment?
problem:  how to place the cursor to the interception point with known Y value....without insert value manually into the start index(0)
attached also my vi for reference
Best Regards
Tarmimi
Message 1 of 10
(5,692 Views)
Good Day
Any help or advise guys?
Best Regards
Tarmimi
Message 2 of 10
(5,551 Views)
To place a cursor: http://digital.ni.com/public.nsf/allkb/280875F12A53D4FD8625699E006F0BBA
To answer your other question, you'll want to traverse your array of data to find the point where it changes from being less than the cursor value to greater than.
Message 3 of 10
(5,517 Views)
Good Day Natasftw
thank for your reply
How can i transverse the array data? can you give an example
best regards
Tarmimi
Message 4 of 10
(5,509 Views)
Do a greater than/equal to the cursor value.  This should provide you with an array of booleans.  Create a loop to run through these values to see when they switch from true to false and vice versa.  Save an array of those switches as an output for your loop.  You'll have all of the interceptions.
Message 5 of 10
(5,504 Views)
 Hi natasftw
very sorry i  still not get the idea (refer attachment) due to my lack imigination in convert into labview programming .... can you help me by  giving a simple example using vi...
Bes regards
Tarmimi
Message 6 of 10
(5,491 Views)
Very quickly thrown together example.  You can change the values in the data array.  You can change the cursor value to be whatever you'd like.  The boolean array is just for show.  You don't need it in an actual application.  This just helps you see each of the elements in the array is checked against the cursor and makes it easy for you to scan the array to see when it changes from below to at/above the cursor.  The final array is a list of all the elements where the value in the boolean array changed.
In the future, attach the code you're working with rather than a picture that shows a very limited piece of your actual work.
Message 7 of 10
(5,467 Views)
Good Day natasftw
thanks for your reply
I did attach my vi code on first posting, re attached again
I try  combine your  vi with mine but still not getting  the  value of X axis with known value of Y...
if you run  example the test measurement exponential.vi  for  cursor C i know the value of Y=0.501176 and X=30, but what i to know is the interception graph when  Y still 0.501176, and X unknown (refer interception of graph picture)
i can change the start index(0) but it seem to response to known X value
Message 8 of 10
(5,432 Views)
Good Day
Any advise on this topic?
Message 9 of 10
(5,334 Views)
Accepted by topic author ahmadtarmimikassim
Good Day
I think i solve the problem, refer to attachement , solution :using the negate
you can also refer to example from http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:ex/q/graph%20cursor/
Thank you natasftw for your kind help and advise
Best Regards
Tarmimi
Message 10 of 10
(5,274 Views)
