graph axes corrupted in build
I have an XY graph... in the Dev environment it looks fine, no changes in ages in the CI log and the last few builds. When compiled s an EXE, it does this, but it didn't used to.
and messes up the Y scale on the left - any ideas?
(even stays like this when rescaled)
Build clears cache, fresh checkout from SCC is fine in Dev... this is not the first time build has done this.. Why is UI getting corrupt?
(LabVIEW 2020 SP1)
Cheers
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
(2,270 Views)
Graph axes have some corruption problems under certain conditions:
Check the following:
  • Font usage. Make sure that you use a defined font (e.g. Tahoma) and not a symbolic font (e.g. "application font".
  • disable "auto-adjust scales" (advanced right-click)
  • Don't mess with font justifications on graphs.
  • Do a "advanced...reset scale layout" for good measure.
  • Replace the graph with a new graph from the palette.
  • no guarantees....
(2,238 Views)
Thanks Christian,
Looked at those.
Built on my PC, no issue, went back to CI maching and manually hacked the output, - seems to be something to do with the Compiled Object Cache (User) not being cleared between running VI Tester and building the project.
If I clear the cache and dont run tests it works - looks like I need to add another step to my build process.
Wierd. (the caches were both already cleared before running the tests, so it can't be the built object cache).
James
(2,194 Views)
Oh dear,
Still having the issue,
Re-looked and first look was obviously terrible I still have:
  • Application font for axes labels
    • (& System font for axe legend)
  • ,auto adjusting scales
  • Left justified scales on Y axis
    Will try and sort again
Thanks for responding to this originally with that list Christian
James
(1,490 Views)
