graph X-axis format
I would like to change my X-axis (time axis) values of graduation. I want to make a numeric operation with each graduation.
For example, now I have got all my graduation from 0 to 0,05 and I want them from 0 to the result of 0,05 / 2E-5. I want to make this operation over all graduation, since when I will zoom on the graph, the scale must be adapted with the operation.
Cordially,
BD
Bonjour,
Je souhaiterais formater l' axe des abscisses de mon graphe (axe des temps). Je voudrais changer la valeur de mes intervalles en appliquant une opération numérique.
Par exemple, mon graphe est gradué de 0 à 0,05, et je voudrais qu'il soit de 0 à 0,05 / 2E-5. J'aimerais faire cette opération sur toutes les graduations, pour que lors d'un zoom, je puisse retrouver cette nouvelle échelle.
Cordialement,
BD
~ La programmeuse compile le C. ~
http://www.pmeonline.fr.st
http://www.nihon-fr.com
http://www.cinemasie.com
http://ippai.free.fr
(2,847 Views)
You may use Proprety Nodes to set axis format in your program. Right click on your graph terminal and select Create >> Proprety Node. It initially has one terminal (Visible by default), and you can set the proprety or get the current state of the proprety.
You can modify the proprety your program will use by right clicking on th terminal and select the proprety you need.
I think you will find all you need in Proprety >> Scale >> Range.
To modify the read/write mode of the terminal, right clik on it and select Change To Read or Change To Write.
Mathieu
Message Edité par Mathieu R. le 10-17-2005 07:40 AM
(2,813 Views)
thank you very much.
(2,790 Views)
