gradient/difference calculation
Hi All
I managed to display two input readings on an X-Y graph. I have one analogue voltage reading for my Y-axis and also counter input from my encoder for the X-axis. Now I am trying to calculate angle of change in anologue voltage reading with respect to counter reading. For this I am using inverse tangent of change in Y-axis divided by change in X-axis. My question is how can I dynamically  find the change in analogue and counter input values so that I can feed it into my formula VI to calculate the angle. I tried to use shift register but no success. Please find the attached VI. Any help is greatly appreciated.
Duran
(3,638 Views)
Try this.  It uses shift registers to get the old data from the last iteration with the new data just acquired.  I can't test it, and I don't usually use dynamic data types so it's possible the math operations won't work right.  But this should give you the idea.
(3,615 Views)
