grab one data point
I am writing a labVIEW program that is measuring strain as well as load.  I have the DAQ Assistant set up within a while loop and I condition the signal first, then extract a portion of the signal and then collect that portion of the data before I take the measurement readings.  I need to be able to tare the data as well as grab only one data point at a time from each instrument when I want to grab the data.
Eventually I also need to write the information to an excel file.
Is a while loop the way I should be tackling this?
Thanks-!
P.S. I'm using LabVIEW 10
(2,525 Views)
For continuous data acquisition you use while loop. so yes, you are on the right track. Is that all you are asking?
Kudos are (always) welcome for the good post. 🙂
(2,512 Views)
