gps programming
What does polling of data mean?
Message 11 of 19
(2,877 Views)
It means that you write a serial command that requests a certain parameter, then read that data.
Message 12 of 19
(2,873 Views)
I have done that for the basic gps unit..now i need to do it for the differential gps setup..can it be done?
Message 13 of 19
(2,860 Views)
In TM4, it has two modes.  Broadcasting mode and polling mode.  Broadcasting mode sending info continuously.  Polling mode, when a command is received, it send out the requested info.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
Message 14 of 19
(2,860 Views)
I am still trying to figure out the logic for the differential setup in labview..have you done differential gps programming in labview?
Message 15 of 19
(2,856 Views)
I never did differicial in LabVIEW for the GPS.  See att for some hint.
Message 16 of 19
(2,849 Views)
That's all I have.
Message 17 of 19
(2,846 Views)
it looks quite complicated.so are you currently working on it?
Message 18 of 19
(2,819 Views)
no. I helped a friend did something using Matlab, that's the info I got from him.  I didn't do any further research on that.
Message 19 of 19
(2,813 Views)
