Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
got input to input error when using subvi to connect another subvi
I want to connect two subvi, one is a serial port setup and the other is serial control, I use a third subvi, connect.vi, to connect two visa reference name together, but I got error" You have connected an inout of subvi to an input of subvil".
However, if I define a visa reference name in the connect.vi and connect to serial control, no complain.
What did I dio wrong? Please see the attached vi file.
Message 1 of 8
(3,882 Views)
Well, of course you have no error when you connect the constant. That wire between the two VIs needs a source. If you ha a VISA Resource out from sbVI 1, then you could wire that to the resource input of subVI 2. That's basic dataflow - connect a data source to a data sink.
Message 2 of 8
(3,869 Views)
Here is my problem, I don't want to display any of the controls in connect.vi, all the controls are in setup.vi where my source should be in.
How am I able to serial_ctrl.vi without showing all of those controls in the main vi(connect.vi)?
Message 3 of 8
(3,853 Views)
In other word. how do I change all the controls in setup.vi to output?
Message 4 of 8
(3,852 Views)
You would have to change the control to an indicator, each one individually.  Right click on the control and select Change to Indicator.
- tbob
Inventor of the WORM Global
Message 5 of 8
(3,843 Views)
I'm confused as to what you're actually trying to write. Did you actually write the "serail_ctrl" [SIC] VI? I doubt it, considering the question you're asking. That has a serial port setup in it, though it's poorly configured as fas as the connector pane.
Message 6 of 8
(3,834 Views)
I can add indicators for each of the controls and the hide them from the front panels, that work-around can solve the problem.
Actually, what I really want  to create a wizard to run setup.vi first, then click a next button to goto another dialog to run serial vi.
Any examples?
Message 7 of 8
(3,823 Views)
I did wirte the serial_ctrl.vi which is my first labview code, it is not quite prety
Message 8 of 8
(3,821 Views)
