got error- "plotsup2.cpp Line 306. failure page says nothing found
any help on the above error code
(3,727 Views)
Was having trouble finding NI SCXI VIs using 8.6. Reinstalled 6.1. Wrote program. Worked fine. Saved to Desktop, closed, reopened and got above error.
(3,701 Views)
Forgot: Had to add NI SCXI VIs from another computer.
(3,700 Views)
The only special SCXI functions that I know about were part of traditional DAQ and since this obsolete, is not installed by default. You simply have to install it. Copying functions from a different location is not enough.
You should really, really think about converting to DAQmx.
(3,689 Views)
OK, now I'm even more confused. What does LV 6.1 have to do with the NI SCXI VIs? What NI SCXI VIs? You should be installing NI-DAQ (DAQmx). If you installed LV 8.6, then you need to install the support for LabVIEW when installing the DAQmx software. This installs the necessary drivers and VIs for the target LabVIEW version.
EDIT: Got sidetracked while composing response, so didn't see Dennis' response.
Message Edited by smercurio_fc on 01-16-2010 11:20 AM
(3,683 Views)
