global references and shared variable stop working
All,
I have been using Shared Variable and References in an RT application (both on the RT and XP side)
Now I created some shared variables and I can not get the data passed from different vi's. I tried making global references, No Go.
LabView 2011.
Anyone have any idea what might be going on.
thanks,
Carmine
(2,563 Views)
You don't give enough information to troubleshoot the problem. Can you show us some simplified code? Thanks!
(2,560 Views)
Basically:
I have a program that runs on its own and stores data in an array. I created a global reference and init it with the reference of the array.
Then I have a second program that runs on its own. This one happens to start and stop. When it starts, it uses the global reference to get the data.
I am also haviong problems with shared variables. My app has shared vars that I created before and run fine. But when I create new ones, the value is not shared between different vi's.
Right now I am seeing this problem on the Hypervisor side. The RT is running fine.
Make more sense?
thanks
(2,553 Views)
