getting two intensity graphs from the aquisition of one signal conroled by a TTL
Hello ,
I'm a newby in Labview and i'm using 8.6 .
I want to aquire continuously voltage and control it by a TTL signal , in the first rising edge , I aquire many samples of the voltage and put it in the first row of the array and stop in the falling edge , and in the next rising edge , start the aquisition for the first row of the second array , and so on ..
we have to do this until to reach 256 rows of each array , and so draw the intensity graph of the two arrays .
The TTL signal must be aquired using the PFIs and we have another TTL signal wich start in the begining of aquiring and wich stopped in the last row acuired .
ps : i need also to make an average of the aquired data in each row so that i get 256 or 512 values for each row of the array .
(2,493 Views)
Hello imados.
What is the issue which you met? Could you attach us your code please?
If you have no ideas how to begin your code I advice to have a look at Getting Started with labVIEW and at the NI examples.
Best Regards.
Romain D.
National Instruments France
(2,479 Views)
