getting the serial pin values
How can I get the voltage values from the individual pins on the serial rs232 port?
(2,754 Views)
Easy ! use a voltmeter !!! 😉
There is absolutely no way to know what the actual potential on a logical in/output is. As a reminder, the original RS232 specs where that 0 was -12 volts, and +12 volts (probably the reverse, but my memories are fadding), althought many of us here have used RS232 connections with 0-5 volts.
Chilly Charly    (aka CC)
(2,749 Views)
The spec is actually +3 to +12 and -3 to -12 for the logic levels. If you want to determine the logic levels of the control lines, the a VISA property node will do that. Select Serial Settings>Modem Line settings and pick the pin. It will return unknown, asserted, or unasserted. If you are testing a UART to see if it meets specs, then as CC pointed out, you'll need to connect a voltage measurement device to do that.
(2,739 Views)
