getting rid of the noise from pressure sensor and load cell
i want to connect my ni 9205 with 3 jpt131 pressure sensor and s500n load cell with the js1010 amplifier. Currently im just connecting the ni9205 pressure sensor with signal positive and common gnd and connecting the power supply ground to the com pin . this particular solution is generating a lot of noise which i need to get rid off , is there any particular wiring i need to do . should i call put gnd to the Ai sense pin? also my pressure sensor has earthing pins should i connect the to a earth ?
(1,169 Views)
This is a LabVIEW Forum.  You show us two manuals, a verbal "wiring diagram", no LabVIEW code, and say you have a noisy signal.  Sounds like you need to talk to an electrical engineering student and learn about measuring signals, grounding, impendence matching (my daughter at the age of 4 used to put her ears underwater in the tub, and say "Impedance Mismatch!"), and related topics.
(1,141 Views)
@Bob_Schor wrote:
My daughter at the age of 4 used to put her ears underwater in the tub, and say "Impedance Mismatch!"..
Your geek influence is really strong 😁. But I'm sure all goes well with her. 👍
Rolf Kalbermatter  My Blog
(1,138 Views)
