getting python code to run in labview
ive been trying to get this function to run all night in labview but i keep getting a "TyperError' message all its supposed to do is output an excel sheet with all the combinations created by the program but im at the point where id just be happy if it could just output a txt file with the combinations if anything. I know the program works in python as ive tested it but i just cant figure out why it errors when i try to call the function. any help would be appreciated
(1,003 Views)
The error was due to data-type mismatch in the output from file.py and the output in the LabVIEW python node. After converting the "valid_sequences" to string in return function, it works fine without any error. Please refer the below screenshots.
Mano Prabha
Certified LabVIEW Architect
(902 Views)
