getting cluster ref from control in the cluster
I have a control ref that is fed into a subVI.  The control itself is part of a cluster that is external code to the VI that I am working.  I want to get the label.text property of the cluster from the control reference inside the cluster that I have access to.  What is the mechanism or property of the control ref that lets me get to the cluster that contains it?
(4,220 Views)
I'm not by my comp with LV, but isn't there a property for elements?  With that, you can extract the element of interest and pull the label property?
(4,217 Views)
I need the label of the owning cluster, not the control which is my challenge
(4,212 Views)
Accepted by topic author id
The GObject class should have an Owner property. I believe that for objects inside a container (like a cluster), this returns the container. The property itself probably returns a GObject reference, so you'll need to cast it down to the Control class to see the label property.
___________________
Try to take over the world!
(4,207 Views)
