getting an equation from a non-linear graph using fitting pallet
Hi all,
Is there a simple way to get an equation from a non-linear graph using fitting pallet in Labview?I've always use best fit linear equation, but when it comes to non-linear, i usually use lookup table instead. Since I'm required to implement the same thing but using another software that I'm not really familiar at, it's really helps a lot to use maths equation rather than a lookup table. So I'm hoping the get the function from the graph attached. can anyone give an idea for this?
Thanks.
Az
(3,352 Views)
Try Exponential Fit or Nonlinear Curve Fit.vi
(3,328 Views)
Thanks KateB,
Actually I used that before but I didn't get a near one. Might be bcoz I don't really know how to use it. So I just used the combination of 5 linear equations. That would give me the most accurate reading.
(3,283 Views)
