get values
Dear Sir,
I would like to get values which are already present in one VI into another VI.
How can i do this in LabView?
Thanks in Advance.
Regards
Chitra
Message 1 of 9
(4,493 Views)
Hi Chitra,
easiest would be to use a wire...
For more suggestions you have to provide more details!
Message 2 of 9
(4,488 Views)
Dear Sir,
I have randomly generated some values in one vi. I need to get these randomly generated values into another vi.
InAdvance Thanks
Regards
Chitra
Message 3 of 9
(4,479 Views)
Suppose VI A holds the data and you need that data in VI B
Then with attached VI's you can do the job
This is if you want "live" data from VI A in VI B.
Message 4 of 9
(4,476 Views)
Hi Chitra,
again: use a wire! It doesn't matter if values are randomly generated or not Smiley Wink
Longer explanation:
Connect the indicator of your random values with a connector terminal. Make a control in the second vi and connect that too with a connector terminal. Put both (sub)vis into one main vi and connect them with a wire! Or: RTFM!
Message 5 of 9
(4,475 Views)
You could also use a Queue, Notifier, Action Engine and VI Server (Alain S' reply).  Here's how to send a String from one VI to another using a Notifier.
(among many options)
Jim
Message 6 of 9
(4,473 Views)
chitrar wrote:
Dear Sir,
InAdvance Thanks
Regards
Chitra
Do you mean that you generate data in one VI and then need it in another?
Then just use the connector of the VI's.....
Message 7 of 9
(4,472 Views)
Hi chitrar,
If you want to pass information to a sub-VI, then I agree with GerdW, you should just use a wire.
If you want to use the information after closing the first VI, then you should write your information to a file and read that file in the second VI.
But I dont quite get why you are trying to do this, please explain your application.
Cheers!
Pattos
LabVIEW Gretchin
Message 8 of 9
(4,471 Views)
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
Message 9 of 9
(4,440 Views)
