get time stamp from waveform data
Hello all,
i am trying to pull out the time stamp from the waveform data if this is possible. I am trying to write it to file, but the express vi doesnt allow for fractional seconds and when i write the waveform data to a string for use with write to spreadsheet, the time data is lost.
any suggestions?
-Matt
(4,855 Views)
Accepted by topic author Wolleee
Use the Get Waveform Components. What express VI? The Write to Measurement File does write fractional seconds.
(4,852 Views)
Thank you Dennis, I figured it out like right after i posted.  Another question though.  So im using a producer consumer loop and gathering data at 1000 samples per channel.  Im trying to write this data to a file with a time stamp, but in the consumer loop when i get the time stamp from the waveform and rebuild the array, i only get one time stamp per 1000 samples.
Any ideas how to fix this?  I can post code if necessary.
-Matt
(4,842 Views)
Make sure you are using a double to express fractional values.  An INT would return values like what you are seeing.
Bill
CLD
(Mid-Level minion.)
(4,837 Views)
There is only a single timestamp in a waveform t0. There is also dt. You can calculate a timestamp for each element if that is what you are asking.
(4,833 Views)
(4,831 Views)
That sounds like what i am looking for.
Thank you Dennis.
-Matt
(4,820 Views)
