get the size of front panel in pixels
hello, I have one more question.
How can I programmatically get the front panel window size in pixels? I mean not by VI Properties.
(7,094 Views)
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(7,085 Views)
Application property node? Not VI?
Are you sure it is for front panel window size? Not for monitor? I don't understand this solution to be honest...
(7,064 Views)
What do you mean not using VI properties? There are properties for window size and pane size and/or position in pixels
_____________
Creator of the BundleMagic plugin for LabVIEW!
(7,058 Views)
Well, I should to do that with property node I think. Not going to VI Properties in File. I tried with panel origin and content rect position, but maybe I did someting wrong or this is not the resolution. To be honest I care only about horizontal size
(7,051 Views)
Accepted by topic author ada_333
You had asked not to use the VI Properties, that is why I was referring you to the display properties.  Try
(7,049 Views)
It works, thanks!
(7,034 Views)
