get task frequency MAX
I would like to know if it is possible to obtain the frequency configured in MAX for a particular task in LabVIEW.
This is in order to run the task configured by the user in LabVIEW as it was configured in MAX: channels, frequency etc...
I've tried differentDAQmx Propoerty nodes and I couldn't find this information.
Best regards
Didje
(2,672 Views)
Accepted by topic author didje007
Hello Didje,
Indeed it is possible to obtain these information.
After configuring your task in MAX, you have to find back in LabVIEW the task created through DAQmx Task Name Constant. After that, you use the DAQmx Timing Property Node in which you can find the frequency you configured before in MAX.
Hope it will help !
(2,645 Views)
Indeed it works.
I actually found this answer after I posted on the forum. But I gave you a Kudo anyway.
Didje
(2,629 Views)
