get parent of child in tree control method not working properly
I simply want to get the parent tag of the selection in the tree control.  The get parent method doesnt work for my case.  Anyone have a clue as to why?
(2,739 Views)
Change Active Item:Tag -> Value
Cheers!
(2,735 Views)
That recommendation above put me on the right path to determine what in more detail the problem was.  If the tree control is a strict type def, this method does not work.  As soon as I disconnect the tree control from its typedef defn, it works...See attached.
(2,695 Views)
