get matrix elements
i have  matrix ( 4 columns) and i want to  apply  different arithematic operations on each column .
how can i do that ???
thanks
(3,200 Views)
Hi oi,
do you actually have a matrix or just a simple 2D array? That is quite a difference in LabVIEW, please use exactly the label that is shown in the context help! (Or show a picture or even better a VI!)
Use either IndexArray, GetSubmatrix - or simple autoindexing of a FOR loop!
(3,199 Views)
i have matrix 51*4 and want to get each coloums as 1-D array??
(3,189 Views)
Hi oi,
I already proposed several solutions. Have you tried any of them?
(3,184 Views)
As mentioned, Index array allows you to get rows or colums of a 2D array if you leave one index disconnected.
To get columns, you need to wire the lower index of the two. Here's example code to get the first four columns of a 2D array.
How different are the arithmetic operations you want to apply? Can you show us a typical example? There are probably ways to do it all at once.
(3,177 Views)
