get X and Y components form 1D waveform array
To all:
I have a quandary about obtaining X and Y data from a 1D array of Waveform.  I can not use the standard waveform tools (get waveform XY for example). I get a message stating I am wiring different data types.  And, if I try to get the data in array format starting with "TDMS read", it only returns the values, not the time stamp or the data point numbers.
So, I am scratching my head how to extract this information without building a new array with the appropriate information.  All other post I read indicate using the waveform tools or assigning a type of data to beging with.
The TDMS file I am reading has properties that were written: sample clock rate and author. Might these values have something to do with it?
thanks for any advice. I have attached a jpg of the block diagram section I would like to manipulate
AL
A. Lopez
(9,094 Views)
You will need to use Get Waveform Components.  The waveform has 3 major pieces of information:  the Y array waveform, T0 (initial timestamp of the initial element), and dt (timing between samples.)  A 4th less commonly used element is a variant called Attributes.
Use T0 and dt along with the size of the Y array, and you could build another array that has a corresponding time for each sample in the Y array.
(9,090 Views)
Thanks for your reply Ravens Fan,
However, I can not use the waveform tools to extract the components. And is the source of my question.
I have attached a JPG of the resulting problem if I use the "Get Waveform Components" VI.
A. Lopez
(9,074 Views)
Accepted by topic author lopez
Going back to your first picture, I see a 1-D array of waveforms. So you will need to use index array to get whichever waveform is of interest to you, then use Get Waveform components.
(9,067 Views)
Thanks Ravens Fan,
that was the step I did not understand.  indexing the 1D array of waveform worked.
thanks
A. Lopez
(9,065 Views)
You should mark Raven's answer as the solution. If you click the Options button, you can change it.
(9,059 Views)
