generating pwm signal ( NDB project )
hi guys,
i've been working on a project for NDB purposed. so this is basically a software project to simulate how an NDB works. image below explains how NDB system basically works.
so basically in this project I make an AM modulation with carrier signal in the frequency range of 195KHz - 1.8MHz and a single tone of sine wave that are only 1200Hz or 400Hz ( which will be changed into morse code next.
the result of this modulation then compared to a triangle signal wave with frequency 18x times multiplication from carrier frequency in order to get rid of noise and unwanted harmony.
This process is needed before this signal exported to power amplifier, because it is almost impossible to process directly from modulated signal without getting its PWM.
I already in the step of getting the PWM signal. but i got a problem to differentiate this pwm signal into 4 different bites, such as a a! b b! , which a! is pwm signal in the phase between 0-pi , b is in the phase of pi-2pi , a! is value 0 on pi, b! is value 0 on 0 or 2pi.
here I attach my building blocks of this project so far.
thank you in advance
yanra
Message 1 of 10
(3,881 Views)
Hi aas,
You really need to explain those "bites" and all that about 0, pi, and 2pi. What is the significance of the exclamation mark after a and b?
Message 2 of 10
(3,868 Views)
@GerdW wrote:
Hi aas,
i wanted to make the generated PWM differentiated into 4 different array
array a for all of the bit in between phase 0 and pi ( 0 - 180 )
array a! ( a not ) for all bit exactly on phase pi
array b for all the bit in between phase pi and 2pi ( 180 - 360 )
array b!( b not ) for all bit exactly phase 0 or 2pi ( 0 , 360 )IMG_20180814_131152.jpg
more or less like image above
effen
Message 3 of 10
(3,860 Views)
Hi effen,
how do you know just from your PWM signal which phase of the underlying sine wave corresponds to which sample in the waveform?
Also keep in mind: comparing float for equality is "not recommended"! Its hard enough to find the exact 0 spot, but comparing with multiples of pi might be even harder…
Message 4 of 10
(3,856 Views)
@GerdW wrote:
Hi effen,
thats why im confused here, i wanted all the bit from positive value of sine wave are stored in array a and all the bit from negative value of the sine wave are stored in array b
Message 5 of 10
(3,849 Views)
Hi effen,
so you need a subVI with two inputs: sine wave and PWM signal.
The output would be two arrays with "bits"…
(I still don't get the sense behind all this.)
Message 6 of 10
(3,844 Views)
@GerdW wrote:
Hi effen,
yeah, i need all of the generated PWM signal stored as array of bits , but differentiated into 2 different arrays as i explained before. if only stored in one array as all the pwm ( generated from positive and also negative values of sinewave ) , I already did that.
Message 7 of 10
(3,840 Views)
Hi effen,
you could something similar to this:
Message 8 of 10
(3,830 Views)
@GerdW wrote:
Hi effen,
hi, could you upload the labview.vi file ?
effen
Message 9 of 10
(3,820 Views)
Hi effen,
I didn't save that VI, I just created it from scratch in 3mins…
You need:
- GetWaveformTimeArray
- GetWaveformComponents
- Index&BundleClusterarray
- Threshold1DArray in a FOR loop
The other stuff should be no problem at all! (You did the basics courses offered in the training section in the header of the LabVIEW board, did you?)
Message 10 of 10
(3,815 Views)
