generating arbitrary wave function
Hi all
I try to generat the arbitrary wave function and I use this example which I attached.
I have 2 question: 1- I dont know about Table Control, what is it?
2-How can I add another function like sin in my plot?
I will be happy if you suggest also another code.
Best regards
(3,321 Views)
Hello vsa
Apparently the Wave Table Control is the amplitude levels in one cycle of the arbitrary wave. You can insert diferent amplitude levels that the wave can reach in every cycle.
To add another function like a sine wave, you can use the simulate signal express vi and a build array function to do so. Also, the Simulate Arbitrary Wave can do the job when creating arbitrary waves. I modify your code, so you can examine how to use this functions.
Hopefully this information will help you.
Omar R.
Technical Support Manager
CLA | CTD
(3,289 Views)
