generating an exponential decay graph
Hey I am trying to generate an exponential decay graph. I have tried a few different signal generator types but nothing has been even close. Can anyone help?
(8,103 Views)
Accepted by topic author dpkiley
What have you tried?  Directly applying the mathematics seems to work.
Lynn
(8,100 Views)
You can use the Exponential Window (Signal Processing >>Windows) on a waveform.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(8,093 Views)
I want to create a sine wave with a gaussian decay, and then use that in an analog voltage output and into an analog voltage input. Any suggestions?
(7,046 Views)
Hey WadMog,
If the graph above is what you’re interested in, you can use a Sine Wave VI with an Exponential Window VI to recreate the curve based on parameters of your choosing. Assuming you’re using DAQmx (are you?), you could then send this data to a DAQmx Write VI to create your analog output.
As this thread has already been marked with a solution, you might consider creating a new thread for greater visibility!
Ross S.
Applications Engineering
(7,028 Views)
Here's one that I have that works.
(6,733 Views)
