generate results table
Hi, I need to generate a results table from analog input values at specified times, for example, every 5 seconds values from the analog inputs would be entered into there respective cells on row 1 then 5 sec's later on row 2 and so on for a set period at the end of this period I need save this data. Im just getting started with Labview so any pointers would be really helpful, many thanks.
(2,793 Views)
Hi alanled,
can you show what you have done so far. You can use the "Write to Spreadsheet File" function to write an array to a file.
Mike
(2,790 Views)
alanled,
While you will probably want to use the write to spreadsheet file or write to measurement file VIs, we have a DAQ example that writes to a TDMS which might be beneficial for structure-sake.
You can find it in the NI example finder by browsing to: Hardware Input Output» Analog Meas»Voltage»Cont Acq&Graph Voltage - Write Data to File (TDMS).vi
Hope this helps get you started!
Chris Van Horn
(2,769 Views)
