generate analog signal using samples fpga
I have 20  samples of (time,data). using these samples i need to write data to AO channel in FPGA card. Here the data should be written to a channel w.r.t time. i need to generate signal(ramp) based on time and data available.
for example -
time( in seconds) -   0   0.01   0.04   0.05  0.07 ...
data -                        0   1.0    3.2      2.5     1.3 ...
Please suggest me best way to achive this.
Thank you,
Ranjith
(3,660 Views)
Keep all ur samples in a array and auto index the array to a for loop, Inside the for loop put a wait timer and give the dt as input(t2-t1) to the timer. Inside the loop connect the auto indexed output to the A0 Channel.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,657 Views)
Hi Balaji,
Thanks for the quick responce.  I need the ramp between two samples. time t1 to time t2, if the data are d1 and d2. will i get ramp between d1 to d2(may be traingle wave considering all samples)?
Thank you,
Ranjith
(3,645 Views)
U need to interpolate between the datas so see the interpolation examples.
Balaji PK (CLA)
(3,640 Views)
Could you please give me a good logic using timed loop to achive signal interpolation using below structure.
array of 20 clusters
float data
float time
time is given in seconds and it can go upto micro/nano seconds precision. time would starts from 0 and will go on...
Data has to be written to analog channel based on above given time and data.
 Thanks in advance,
Ranjith
(3,609 Views)
I could not use interpolation vis in FPGA vi. Can any one has fpga supported interpolation vi?
Need help on this..
(3,582 Views)
