generate DTMF-tones
i want to generate DTMF-tones. I found an example: "Sim phone.vi" but this vi generates very short tones. I want to have them longer (adjustable). I can't figure out how to do this. If i try to make it continuous (by looping) it has discontinuities.
best regards,
Joop Tap
(3,175 Views)
Hi Joop.
Go into the "tone gen.vi" and change the number of samples you want to generate. Experiment with that and you will be able to map time to number of samples to achieve your goals.
Hope it helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,175 Views)
Hi Alipio,
yes, this works!
tnx
(3,175 Views)
