gaussian fit with LevM
Hi people,
I am actually programming a fitting programm. My idea is to calculate the amplitude and FWMH of an absorption peak.
The fit I would like to implement is gaussian+linear: a*exp(-0.5*(((x-b)/c)^2))+d*x+e with a,b,c,d,e as variables and x the X.
The problem is that my VI always gives me a "wrong model equation".
I'm not use to labview, could you please help me.
Félix
(3,436 Views)
Accepted by topic author felixd
Hi Félix,
take the Curve Fitting Express VI, the handling is much easier and you can test your initial values for your parameters on the fly (you have a preview window which shows you the impact of each parameter change)
Hope this helps!
Cheggers
Sascha
(3,380 Views)
Sorry was in vacation, thanks for your help. It helps and I can move on a new improvment for my mini-soft.
(3,353 Views)
