fzero - zero finder numerically in LabVIEW - NOT based on formula
Hello All.
Does anybody have a simmilar function to Matlab "fzero" in LabVIEW?
I do not need anything less advanced?
thanks in advance
Pawel
Message 1 of 9
(4,972 Views)
Hello Pawel
Have you checked out the functions in the palette "All Functions < Analyze < Mathematics < Zeros... They might be what you are looking for.
Mohadjer
Message 2 of 9
(4,972 Views)
I want to use fzero to minimise a function of many variables, but with only one variable to be minimised. The other are just constants. In MATLAB I would do this by using something like :
x=fzero(@(x) myfun(x,a,b,c),x0)
where x is the variable to be minimised.
Unfortunately MathScript doesn't seem to accept the handle @, which leaves me stuck. Any ideas how to get round this problem?
Many thanks,
Steve.
Message 3 of 9
(4,766 Views)
Sorry I did actually mean find the zero of the function, not minimise it.
Message 4 of 9
(4,759 Views)
Hi Steve8.5,
Mathscript does accept the fzero function. Here is a link for the syntax.
I hope this helps!
Warm regards,
Karunya R
Message 5 of 9
(4,741 Views)
I know that fzero can be used, and works fine with one variable. My question was regarding finding the zero for a function of more than one variable, but with only one to be changed i.e. not a system of equations.
Message 6 of 9
(4,736 Views)
Hi Steve8.5,
Have you tried using fsolve? Here is a link to explain the difference between fzero and fsolve.
Warm regards,
Karunya R
Message 7 of 9
(4,708 Views)
Yes, and that has exactly the same problem, as the problem is with the use of @ rather than with fzero itself. However, I have worked out a solution using global variables instead, so that my function can be of just one variable with the other variables passed to it by making them global.
Message 8 of 9
(4,696 Views)
Hello Steve,
MathScript does not support the @ syntax, as you note.  A workaround is to simply type the name of the function you wish to call.  For example,
x=fzero('myfun', x0);
Also, the function parameters currently only accept one argument.  This is a limitation we are aware of.  The global variable route is the workaround we recommend.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
Message 9 of 9
(4,611 Views)
