function
How to implement the function ( integration function)" integral(Yn)= Yn-1 + Yn   *  dt  " Please suggest the vi and procedure to build this function
Message 1 of 9
(4,617 Views)
Hi Vika,
start like this:
Message 2 of 9
(4,606 Views)
hi...
    How do you get a sample time dt???
Message 3 of 9
(4,603 Views)
Hi Vika,
I don't know: "dt" is part of your equation and you should know this input on your own…
Well, you might use a samplerate of your DAQ here. Or you need to calculate dt by subtracting timestamps.
Message 4 of 9
(4,600 Views)
        Can you tell me how to calculate delay by subtracting time stamps and how to use sample rate of DAQ.
Thanks in advance
Message 5 of 9
(4,591 Views)
Hi Vika,
when you set a samplerate to your DAQ task you already know dt as dt= 1/samplerate.
To calc dt based on timestamps is quite easy:
This is all very basic LabVIEW stuff so I recommend to go through all those free online courses offered by NI and to study all the relevant example VIs coming with LabVIEW!
Message 6 of 9
(4,588 Views)
hii
I have implemented the same way as you told. But I am getting Zero as answer everytime . Even Current time is zero and time since 1st jan 1904 is zero
Message 7 of 9
(4,583 Views)
Hi Vika,
I don't believe "Current time" is zero! The only use case when the snippet above will give zero is when you call it more often than 1000 times a second…
Please show your VI or block diagram!
Message 8 of 9
(4,579 Views)
hii,
 It was a silly mistake. I got it. Thank you soo much
Message 9 of 9
(4,574 Views)
