function to generate cosine and sine in FXP in Labview FPGA
Dear all, reading a FPGA vi in Labview 8.6 I have found a function to generate cosine and sine in FXP in Labview FPGA,
but I could not understand whether it is a built in function or a subvi.
I attach the icon and explanation .
Does anybody know whether it is a built in function or a vi.
regards
Max
Message 1 of 14
(5,254 Views)
Dear Max Tomatis,
 "To generate cosine and sine in FXP in Labview FPGA" it is a built in function.
Best Regards,
Enzo Perini
Message 2 of 14
(5,216 Views)
Dear Enzo,
you are right, there is a built in function to generate Sin in Labview 8.6,
but it is not the same icon as the one  that I have reported in my post.
Do you know if it is possible to find function with the same icon?
Regards
Max
@enpe wrote:
Dear Max Tomatis,
Best Regards,
Enzo Perini
Message 3 of 14
(5,208 Views)
Dear Max Tomatis,
I'm sorry but that icon does not exist anymoreyou can not retrieve it.
Regards
Enzo
Message 4 of 14
(5,199 Views)
This function is part of the Fixed-Point Math Library from NI Labs.  Beginning with LabVIEW FPGA 2009, it has been integrated into the product, but in versions 8.5 and 8.6, you must download the library and install it into your LabVIEW installation.
Donovan
Message 5 of 14
(5,185 Views)
Thank you Donovan, I am going to install it ...
Max
Message 6 of 14
(5,181 Views)
I have installed the Fixed-Point library through the setup.exe but I cannot find it from the FPGA block diagram.
Please, could anyone explain me where I could find it from the FPGA block diagram?
Regards
Max
Message 7 of 14
(5,160 Views)
If you don't see the "FPGA interface" like option in the function palette of block diagram you can see in "user library" option.
Enzo
Message 8 of 14
(5,156 Views)
Hi Enzo, sorry but I do not see the reference to this library. Should I go through the directory tree  or import it from somewhere else?
Max
Enzo
Message 9 of 14
(5,152 Views)
you have to download  .zip file that you want to unzip and place in the following location:
--> C:\Program Files\National Instruments\LabVIEW 8.6\Targets\NI\FPGA\menus\FPGACategories
you can proceed with the installer. After you should be like this:
--> C:\Program Files\National Instruments\LabVIEW 8.6\Targets\NI\FPGA\menus\FPGACategories\Fixed-Point Math\
Containing the following .mnu files:
--> Dir.mnu
--> BasicElem.mnu
And so you should find the fixed-point library  in the palette.
Enzo
Message 10 of 14
(5,145 Views)
