fuction in the dll
hi
I met some difficulty.
In what way labview can call one of this function in the dll?
the function parameter is a pointer,which point to the return value.
the parameter is a LPDWORD,and the return value is DWORD.
I tried to config the parameter and retrun value in the clf (according to  the dll guide in the ni develop zone),but the error message always say the dll corrupted the labview memory.(the error message is in the appendix)
I do not know what can I do, how can I config the parameter and return value in the clf.
thanks
(2,509 Views)
LPDWORD is the same as pointer to U32 in labview.  To setup the parameter, set the parameter name, Type=Numeric, Data type=Unsigned 32-bit Integer, Pass=Pointer to Value.
One thing that can cause your error is the wrong calling convention.  The default selection is "C".  Try changing this to "stdcall (WINAPI)".
- tbob
Inventor of the WORM Global
(2,492 Views)
