ftp software and listbox selection
I am wondering if someone can help me with my program.
Part of my program requires me to design some ftp software.
I need to be able to read the row which the user has selected and then when the user hits one of the main buttons (i.e. Make Dir, Rename, View, Delete) be able to act upon that file.
Therefore if the user selects Rename or delete, the program must rename the file or delete the file from the list box.  Similar to professional ftp software.
My problem is identifying the selected row and using the value effectively.
(3,028 Views)
You need to have the file that your code interface node loads so that way i can test to see what is wrong with your program.
p.s.. please have it apple friendly. Thanks
(3,019 Views)
This is basically a stand alone module, that will be used within the main program.
(3,017 Views)
I cannot run your program unless I have that file
(3,013 Views)
Sorry.  Hope this helps.
(3,001 Views)
Hi Preitano,
It's very easy to get the value of the for exampel the "PCfiles Listbox". It simply returns an array with the index of the selected row. Is this what you are having issues with?
Please let me know exactly what it is that is not behaving as expected, thanks.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,974 Views)
