fsolve don't work
Hello.
I have a problem with fsolve function. can u help me please?
I think that fsolve function should be work correctly in mathscript node, but I cant use it in my math script node code. this is my code that correctly work in MATLAB:
x0=[150;.00001;1.5];
x1=zeros(Npump,3);
%% make pump curve
for ii=1:Npump
    kk=0;
    QH=zeros(1,3);
    HQ=zeros(1,3);
    for jj=1:2:6
        kk=kk+1;
        QH(kk)=DisQH(ii,jj);
        HQ(kk)=DisQH(ii,jj+1);
    end
    save Q QH
    save H HQ
    x1(ii,:)=fsolve(@pumpcurve,x0);
end
can u help TO find problem?
(4,026 Views)
Code snippet of your runnable VI?
(4,021 Views)
excuse me ToeCutter, I dont understand your mean. this is a part of my code that I have problem with. my code is perform except this part
(4,017 Views)
Hi behzad,
error codes? Error messages? What do you get?
(4,011 Views)
fsolve() uses Optimization Toolbox. LabVIEW's MathScript does not load toolboxes. You may think about finding the files required for running fsolve() and copying them into your working directory.
Check out some other threads: http://forums.ni.com/t5/LabVIEW/Calling-MATLAB-SOAP-From-MathScript/m-p/1237926/highlight/true#M5241...
(4,001 Views)
thanks a lot ghighuphu. I'll try your suggestion. is any function for nonlinear equation instead of Fsolve?
Hi GerdW, thank u too.
(3,961 Views)
Have you tried searching in the functions palette for "nonlinear?"  The search function is how I got around the various palettes until I learned where most of the stuff was.  🙂
Bill
CLD
(Mid-Level minion.)
(3,954 Views)
