front pannel scroll bar get disabled(not visible)
  I am facing some strange problem with Lab View front pannel. I am doing some expriement with PictRing vi which is in Ring&Enum. Then while doing this I lost my scroll bar(both vertical & horizontal) from front pannel. But it's present in block diagram of same vi. I deleted the PictRing vi and restarted my pc considering it may visible the scroll bar but it's not working. If I create new vi their on front pannel scroll bar is appearing. What might be a problem with my vi?
         Thanks in Advance.
Mike
(3,234 Views)
What version of LV are you using? Can you post your VI?  I would be happy to take a look see.
Is it possible that  you turned scrollbars off?
Got to VI Properties>>Window Appearance>>Customize and make sure that the checkboxes next to Vertical/Horizontal Scrollbars are turned on.
If you are using multiple panes you may have to turn scrollbars on individually.  You do this by right-clicking on a splitter and selecting the visiblity of the scrollbars on a per-pane basis.
Finally,  if you have set the option "Fit Control to Panel/Pane" this can also turn off your scrollbars.  Again, you can just reenable them via the VI Properties box or the splitter popups.
Jeff Peters
(3,216 Views)
HI Jpeters,
       Thanks for your valuable input. In VI Properties -> Windows appearance  Custom option get's selected that's why the scroll bar get disabled.Now I selected default option and both scroll bar(horizotal and vertical) are visible now.
         Do you have any idea how it's happes? I might have used Fit Control to Panel/Pane....
         Also when the scroll bar get disabled, my GUI gets distorted.... Now I enable the scroll bar but still GUI remain the same(distorted). Can u please let me know how can I get back my previous GUI?
Thanks again.....
Regards:-
Mike
(3,203 Views)
Mike,
I couldn't find any way to revert controls or indicators to their default size.  I've created a product suggestion internally.
Trey B
Applications Engineering
(3,184 Views)
