front panel
Dear sir
        I have did a program for serial communication with embedded system in which i have to display two front panel for this single operation . and i have to display the message in one front panel and display parameter (like baud rate, com1, start bit , stop bit ,etc)in another front panel. if i change the parameter all should change .
(2,867 Views)
There are many ways to get the solution.
1. In your configuration panel make one configuration file. That file you can read in other panel. If you got any change in your file you can stop your acquisition and configure your system with new settings and start acquisition.
2. In your configuration panel you can make a configuration cluster. You can share this cluster with your second panel by using any communication mode. If your cluster value change you can stop your acquisition and restart you acquisition with new configurations.
Basically you have to pass the parameter from one VI to another VI and check the parameters on real time, to transfer the setting there many ways.
Its up to you that you feel comfortable with which mode.
Thanks and Regards
Himanshu Goyal
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,866 Views)
sir do you have example related to that ... or can you explain how to configure actually i am new to labview that why sorry
(2,856 Views)
Duplicate Post
Please don't ask the same question multiple times in multiple places.
(2,844 Views)
I thought this looked vaguely familiar.Smiley Wink
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(2,819 Views)
