front panel scaling question
When I set my main VI to scale front panel objects with the window size, it mostly does what I want but there is one flaw. In the two attached pictures you can see what is going on.
When the window is 'normal sized' (which was sized so that it would work well with 1024x768 resolution) everything is aligned as I would like, however when
I maximize, the cursor controls that were lined up with the right edge of the table seem to get bigger but not move over. (I hid the cursor legend under the controls as the legend itself didn't meet my needs). Is there any way to correct this?
If not, could I get the behavior I want by making my own cursor control that is not a part of the graph, but would do the same thing via an event structure?
(2,746 Views)
hi scrook,
  These are the problems with the resolution of the controls.So my best advice is to disable the restore button.So for any window you enable only minimise and close buttons.
Thanks and regards,
srikrishnaNF
Srikrishna
(2,691 Views)
