front panel problem
i wanna to build program which when user press button new front panel open and so on,all front panel must be with same size only controls& indicators replaced by controls& indicators of the new one
(4,234 Views)
You can use the concept sub vi,
you can use as many you want
check the option   subvi node setup>> show front panel when called, this will a new window.
see window size in  property node of VI for same size
Regards
Shrek
(4,227 Views)
Can use the visible function for each of the controls and indicators.
(4,224 Views)
Create subvis. Go to file-->vi properties-->windows appearence-->customize-->now un select resize window and minimize window option and also select open front panel when called and close afterwards.
(4,222 Views)
(4,214 Views)
or you can also place each control/indicator over each other and use a property node like this
(4,211 Views)
