front panel always on top
Hi everyone,
I want my front panel of my LabView on top above anything else. So even if I go on an internet browser or use some windows application my LabView frontpanel would still be visible. for context, I am reading out some measurements, and would like to display these at the top bar of my screen. I am using LabView 9. does anyone have some suggestions?
Best Regards,
Thijs
(3,686 Views)
Have you already read this post?
How do I keep the front panel on top of every windows (including non-LabVIEW windows)?
Certified LabVIEW Developer
GCentral
(3,660 Views)
thanks for your fast response, but I tried it and it doesn't give me the result I would like. So with the method you mentioned my VI is in front of all other LabView VI's. But is is till behind Windows based applications. I attached a photograph so you can see what I mean.
In the photograph you can see my running VI is in front of an other VI. But it is still behind a folder of windows. My goal is the get the file from windows (or any other application) behind my running VI.
(3,637 Views)
