from c++ to labview - help needed
hello, i have a problem to transform a c++ program to a LV VI
i have done a VI but it's not correct and i can't understand where i made mistakes.
Someone could help me?
I use LV 7.1
Using LabVIEW 7.1
Message 1 of 8
(4,295 Views)
Your best bet is to compare the values generated by various stages of the C and LabVIEW versions as they execute. You can do this a bunch of ways in LV- 'highlight execution' is handy. This will allow you to narrow it down to the exact point where the behaviour diverges.
Message 2 of 8
(4,282 Views)
i can't...where i work i can't execute c programs
Using LabVIEW 7.1
Message 3 of 8
(4,273 Views)
No problem- you have a web browser. You can test your C code online. Google 'online C interpreter' and you will get a bunch of hits.
Message 4 of 8
(4,268 Views)
you start by extracting the 2nd element of an array and then use the double value +1 as index ... What are you trying to achieve?
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(4,260 Views)
i dunno 😞 i'm just trying to copy the c program ...i can't understand the c program 😞
Using LabVIEW 7.1
Message 6 of 8
(4,254 Views)
I created the code below before looking at your code.  They are very similar with one difference: additional shift register.
I may have made a mistake, but look at it just in case...
Message 7 of 8
(4,228 Views)
thanks...i'm going to study your VI
Using LabVIEW 7.1
Message 8 of 8
(4,211 Views)
