frequency setting
I'm using Labview in order to control a digital compact receiver. I need to take spectral acquisitions: frequency and level. The acquisition normally start at a freq start and ends at a freq stop.
The problem is that if I define a fstart >= 1.4E+8 Hz , labview does not work, and I have no acquisition. If fstart is below 1.4E+8 Hz, it works fine.
Do someone know if there are some limitations in Labview in setting the frequency ?
Paola.
(2,726 Views)
Paola,
Labview doesn't have limitations on numbers (at least not relevant ones), but the program may limit the ranges you can use and of course the hardware as well.
Cheers
Edgar
(2,721 Views)
