frequency estimation using labview fpga
hi member
i want to caculate the frequency of the input ttl signal using lab view fpga
how can i do this??
hi ?Q>
(3,297 Views)
What you want to do is use a Single Cycle Timed Loop to read the signal.  Use a shift register that holds how many cycles have passed since the last rising edge.  On the rising edge, reset the counter and calculate the frequency.  The frequency will be 1/(Numer of Cycles*Cycle Rate).
(3,273 Views)
can you show me the vi plaese>>>???
where i put the counter inside or outside the single loop cycle!!
hi ?Q>
(3,268 Views)
I don't have the resources available right now to build this up.  Since you are updating the couter with each cycle, it should be inside of the SCTL.
(3,229 Views)
